HAL.Card.PortPartMisMatch
Description
The configured port partitioning does not match the current port partitioning applied when the switch was initialized. The switch is operating with the current port partitioning setting as reported in show ports information detail. This will occur if the port configuration for a slot was modified when the switch was not present in the stack, a new switch replaced the previously configured one, or a new configuration file was loaded with a different configured port partitioning for the slot. The system has automatically stored the configured port partitioning in the node but the switch needs to be rebooted for it to take effect.
Remedy
Reboot the switch to apply the configured setting which will then become the current setting. Or modify the setting, save and reboot to apply a new setting.
Severity
Warning
Message Text
The current port partitioning for %slotName% does not match the configured setting.
Message Parameters
Name Type
slotName String
Applicable Platforms
